5.3/powerglide question
ive got a 5.3 and want to run a powerglide. i know its been gone over and over and beat to death, but i just cant find what im looking for.
what flexplate do I use (5.3, 5.7, 6.0?, what converter do i use( ls based or one for a sbc350/p-glide)? ive read a bunch about spacers?? Do you need one? im lost.
you will use a LS flexplate and in your powerglide you will use a turbo input shaft so you can run a 350/400 converter (the beauty of a turbo input shaft is that it is thicker than a powerglide input shaft so its stroner) but you will have to have your converter mounting tabs set up for LS base flexplate. Im running a powerglide behind my 6.0
what brand of converter are you running?
i found this.....
http://www.summitracing.com/parts/HUP-HP3795/
when running a spacer, which flywheel and converter do you use?
and this....
http://www.summitracing.com/parts/ADD-712500A/
what do you guys think?
i found this.....
and this....
LS1Tech Sponsor
wvjeepers,
we have everything that you need to install your glide from the trans itself to the flexplate and custom built converters.
Greg
FTI
1-866-726-8358
Greg
FTI
1-866-726-8358
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
1-866-726-8358
FTIPerformance.com
