P0751 Light Came On
Old 02-24-2010, 07:17 PM
Yahelou's Avatar
Default P0751 Light Came On
so check engine light came on today, code read P0751-Shift Solenoid A Performance. stall is stock. car was shifting kind of hard lately from first gear. i did have the shift points changed last week after i switched from 2.73s to 3.73s gears. anybody have any ideas?
Old 02-24-2010, 09:14 PM
Yahelou's Avatar
anyone??
Old 02-25-2010, 10:55 AM
LS1Tech Sponsor
performabuilt's Avatar
well the ratio calibration for the gears could be wrong. Or the solenoid may actually be bad. However with the recent gear changes i would think in that direction. Is the speedo reading correctly now?
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 02-25-2010, 11:45 AM
Yahelou's Avatar
no its still bouncing like crazy. im sure i have alot of transmission problems. it just doesnt seem to be acting right lately. might give me a reason to change to a manual. how do i check to see if the solenoid is trully the problem? the car seemed to be shifting good after the tune. but now its shifting harder. thanks for the help. i do appreciate it.
Old 02-26-2010, 11:42 AM
green28's Avatar
I'm throwing the same code and I didn't have it until after I did the same gear swap. I remember reading that people have P0751 tuned out when the add a larger stall converter. Should I replace the solenoid even though I am putting in an SS4000 in a few weeks, since it will get tuned out anyway?
Quick Reply: P0751 Light Came On
