4l60e/4l80e swap crossmember info needed
Old 02-27-2010, 09:40 PM
lmt0705's Avatar
Default 4l60e/4l80e swap crossmember info needed
i currently have a bmr body mounted torque are mount/crossmember and I was wondering if this will also work as my crossmember for my 4l80 or do I need something else? If I need a different one can it be modified to work?
Old 02-28-2010, 07:34 AM
MUSTANGBRKR02's Avatar
Almost positive you need the 80 specific mount. You should be able to sell yours and recoup some of the cost.
Old 02-28-2010, 10:53 AM
lmt0705's Avatar
the torque are is in the same place, only difference would be the location of the trans mount. does anyone know how far off they are?
Old 02-28-2010, 01:56 PM
You can modify the stock M6 mount to get it to work if you have a tunnel mount TA
Old 02-28-2010, 03:45 PM
lmt0705's Avatar
so im prob. better off selling mine and buying a new one then. do they make a crossmember that has a provision for the body mounted torque arm?
Old 02-28-2010, 04:04 PM
tals7's Avatar
Smile
you might want to check out bmr.
Old 02-28-2010, 07:30 PM
lmt0705's Avatar
i will thanks, I just bought this thing and it pains me to have to get rid of it already
Old 02-28-2010, 09:01 PM
Gingervitis Addict
slow67's Avatar
Both BMR and Yank make crossmembers that work with trans mount and tunnel mount tq arms. I have the Yank with no complaints....The BMR you can also adjust the pinion angle.
Old 02-28-2010, 09:36 PM
lmt0705's Avatar
i can adjust that on my torque arm so ill probably go with the cheaper of the 2
Old 02-28-2010, 09:49 PM
Gingervitis Addict
slow67's Avatar
Yank with a stock-style torque arm mount is cheaper (thats what I have).
Old 02-28-2010, 10:37 PM
lmt0705's Avatar
its funny you mention that! I had to do the same thing on mine for my 4l60
Old 03-01-2010, 02:48 PM
Racer383's Avatar
My bmr 80e crossmember is the only thing I have gotten from them lately that has fit right. lol. Bolted right up. K-member was a different story but it finally went in.
Old 03-01-2010, 03:51 PM
lmt0705's Avatar
probably because we make SO much power and we twist our cars up before putting there stuff on!
Quick Reply: 4l60e/4l80e swap crossmember info needed
