builders please help?!?! 4l60e problem
ok so here it goes. tranny goes out in the burban so i decide to build the one i have in the floor instead of rebuilding the one in the truck.
build list includes complete rebuild kit with new clutches and bonded pistons. wide red eagle band, 3-4 Zpack, new converter, and a trans go HD-2 kit.
so i put it in the truck and it worked great for about 2 days then it started slipping or hunting on the 3 to 4 up shift and the 4 to 3 down shift and would not act right unless the tranny down shifted all the way to first. then it threw a 1-2 solenoid code and started taking off in 2nd unless put in manual
1st then lost over drive.
so i pulled the valve body and changed the solenoid and found the 4-3 valve stuck. i also pulled the servo out and checked it. put it back together and the code was gone but still no OD.
so after about a week and a half of this crap i decide to pull the tranny back out an i found the 3-4 pack burned up. and when i pulled the snap ring the clutch pack shot out like one of those snakes in a can.
so i pulled the whole tranny down looking for anything else and found nothing. so i put back together with stock 3-4 clutches and steels allong with a new peperator plate and a sonnax 3rd accumulator check valve.
well when i drove to the end of the street i was supprised when it went into OD but got very pissed when i turned the corner and it was not there.
everything else workes fine and as it should, nice firm positive shifts 1-2 and 2-3 and lockup real positive also but no OD.
please help im ready to blow this thing up
2 n3 gear slip 3rd tranny 6 months
My tranny went out about 6 months ago it's a 4 L 60 e I bought a used one about a month down the road same thing 2nd 3rd gear started slipping bought another one just put it in drove it last night okay drove it to the store this morning okay Less store 3rd gear slipping I'm poor I can't afford to keep going through this what is causing me this problem and how can I fix it
"I'm poor"
add up the cost of the 2 (soon to be 3) used transmissions...the fluid...and your time (because if you had the time and energy to swap trannies...you had the time and energy to pick up extra hours at work)
Then compare that to the probably $1100-1300 bucks a properly rebuilt stock 4l60e would be from a local reputable builder.
Cost benefit analysis will show that your wasted time and money on used transmissions was probably a **** idea.
also...clean your MAF sensor. Repeat trans failure can often be traced back to line pressure issues that can be caused by a multitude of things both mechanical and electrical...but a dirty/bad MAF sensor will cause issues every time.
