Stock/Aftermarket tranny cooler lines
Anyone know where I can buy some stock or even aftermarket tranny cooler lines for a 4L60E? Dealership discontinued them a while ago. Thanks guys.
5/16 brake line should just be fine for replacing the your lines. that is what I used. or if you want you could go with a 6an braided line but not really necessary unless your gonna do a lot with your ride. If you went braided you would have to change fittings and prob want to just throw a cooler on the other side.
Summit or Jegs should have a transmission line kit for you to purchase. Call either of them up and they should hook you up with what you are looking for, either hard lines or braided. Junkyards aren't bad either, but it can be hit or miss trying to find what you are looking for.
You can find them on ebay. or if you have the line that goes into your tranny just cut it off after it comes out of your tranny and get some steelbraided hose and slide it over it and use two clams then get a aftermarket tranny coolor and run the lines to it in front of your raidator.
Dont use your factory tranny cooler get a b&m the bigger heavy duty cooler. Jegs has the cooler lines cheap with fittings
