Stock trans rpm limit?
I spin my tranny to 7,000 rpm with all the good parts installed. seems to hold pressure fine. I did have a stock rebuild(2,000miles on it) in there a few years back that started slipping on the 2-3 shift with a mild bolt on ls1. On teardown and inspection/ reaserch I found it had the dual stock springs. At the time I was revving to 6,500.
The Hydra-Matic 4L60E Technicians Guide states that the maximum shift speed is 6000 rpm...
it is probably conservative by a few hundred rpm.
Edit: I also added the 4L80E specs from the 4L80E HMTG.
