4000 converter question
Old 03-03-2010, 09:56 PM
BobSS's Avatar
Default 4000 converter question
Im looking to get a yank 4000 RPM speed torque converter and had a few questions..
will i need to get a tune on the car to up the rev limiter or anything?
and will i need to do anything to pushrods?
Old 03-03-2010, 10:03 PM
01ssreda4's Avatar
you may need a tune to keep it from throwing a code and a check engine light. Also, it helps to fine tune your shift points and lock-up speed.
Old 03-03-2010, 10:04 PM
edwardzracing's Avatar
A tune with that high of stall converter is probably a really good idea. You won't have to mess with the rev limiter... you're not going to be revving the motor any higher simply because of a higher stall converter. The tune will mostly be for adjusting shift points, and checking for false knock often found with higher stalls. Plus the car may throw a code that will need to be deleted... something transmission related, but I can't remember what it is. Someone else will probably chime in and help.
Shouldn't need to change the pushrods. Like I said, you're not going to be turning the motor any higher so no sense in making a change like that without needing to. Good luck. High stalls kick ***!
