1993 4L60 TV cable assist, Corvette /ASR
Old 03-13-2010, 11:01 AM
Steve40th's Avatar
Default 1993 4L60 TV cable assist, Corvette /ASR
With the exception of putting the pan back on and exhaust, I am stuck here. I have adjusted the TV cable several times yet it sets this far from the plunger. It goes to WOT fine, and the throttle goes to WOT fine, but upon return the tv lever goes out quite far. The plunger is as far out as it can go, so hydraulics wont send it further towards the lever. Can I adjust the TV cable a little out to put the lever at the plunger at idle.
Cant afford to screw this little procedure up.
Here is the procedure
And a picture of the ASR stuff
Old 03-13-2010, 11:12 AM
FLT
FLT's Avatar
You will need to tighten up the cable some or replace it if it is stretched.
Old 03-13-2010, 11:22 AM
Steve40th's Avatar
Thanks Vince. SO I can adjust the cable to get the lever right up to the plunger? I just want to make sure the lever pushes the plunger all the way in and returns to right on the edge?
I know I can adjust the throttle body seperately if it is a little off for WOT.
Adjusted it to here
Quick Reply: 1993 4L60 TV cable assist, Corvette /ASR
