4L60 Manual Valve body
Wanted to know what is the best manual valve body that can be used on the 4L60? What is needed tune wise if anythng? Is it worth it?
Thanks
Thanks
I deal with a guy that makes them out west.I have tried several and his works the best.Stay away from TCI.Nothing is needed tune wise it is a direct bolt in the trans does not need to come out.You will love it.PM me if you need any help.There are some things you should do inside the unit to get the max out of it & durability.
