TH400 People Come in
What are you guys using for dip sticks? Ive mostly seen in my searches Madman hard tube or Lokar. Also what length Lokar? Ive seen people say 36 inch is to short...I seen someone else post up to use a 44 inch. Also pics of where you mounted it would be great also if ya used the Lokar.
Location: Your girl's back door giving her the long stroke while you're at work
I used the 36" Lokar stick when I swapped in the TH350, it's plenty long enough.
Mine is mounted where the PCM used to be
