4L60E to Th350? Gurus come in.
Old 03-29-2010, 05:07 PM
odarabla's Avatar
Default 4L60E to Th350? Gurus come in.
I just ordered my TH350 today and are trying to get all the parts together for the swap. I already bought the transmission cross member for the swap and it will be the same size as the 4L60E so I won't be needing a new drive shaft. I know there is some sort of sensor that can be installed on the tale housing of the transmission so I can hook up my speedometer. Where can I get this from and is there anything else I am going to need for the swap? Thanks
Old 03-29-2010, 05:34 PM
1mean96ss's Avatar
chasis mounted torque arm, the stock driveshaft can be used with a 9in tailshaft housing on the th350. youll need a new trans. mount. Aftermarket crossmember is a tad different then a stock 4L60E.
Old 03-29-2010, 06:00 PM
odarabla's Avatar
I bought the crossmember for the TH350 already and the BMR torque will attach to the new transmission cross member.
Old 03-29-2010, 07:35 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
post #3 in the link below has some info for the speedo
https://ls1tech.com/forums/automatic...questions.html
