My 4L60e Fail & Rebuild Thread - Lots Of Pics
Well got sick of crappy workmanship from a certain company and decided to hire me a real builder...
All the parts in the fail are not bad, but you can see which ones are. This is after 5 hours of driving. No hard pulls or stop and go, all interstate.
The Fail..
Reverse Input Drum(bottom), got so Hot That the Fingers got Pushed Out and Don't Line Up Anymore with the Reverse Reaction Drum/Shell
Snap Ring Not Fully Seated in Reverse Input Drum
Burn't Low/Reverse Steels
Stock Return Springs
Stock Input Sprag Exploded
4-Pinion Rear Planetary
Washer Style 3/4 Clutch Hub
Snap Ring is the Stop for the Reverse Reaction Drum/Shell.
3/4 Clutchs Burnt
Top Pressure Plate for 3/4 Clutch Pack got Extremely Hot
Scarf Cut Input Shaft Rings Instead of Solid Ones
Reverse Input Drum was Stack with way to Much Clearance
4-Pinion Front Planet
Primitive Style Babbit Pump Bushing in Bad Shape
10 vanes with Stock Rings
Scarf Cut Rings instead of Solid Rings
Band Toasted the Reverse Input Drum
The Fail..
3/4 Clutchs Burnt
The rebuild...
HD Low Roller Clutch/Support
"Beast" Reverse Reaction Drum/Shell and Front Ring Gear
5-Pinion Rear Planetary
5-Pinion Front Planetary
Input and Reverse Input Drums Installed along with High Energy 2-4 Band
Pump Installed
New Bell Housing to Case Bolts
New Molded Pistons
Centrifugal Apply Resistance Springs that sit on the 3/4 Piston
Cetrifugal Apply Resistance Springs that sit on the Forward Piston
Kolene Forward Steels
Kolene 3/4 Steels w/ High Energy 3/4 Frictions
Super Hold 1-2 Servo Piston
1-2 and 4th Ready
Servo Assm. Installed
Bearing Type 3/4 Clutch Hub/Front Ring Gear
Rear Sun Gear w/Lube Slots
Front Sun Gear w/Lube Slots
13 Vane Pump w/Hardened Rings
Dual Cage 29 Element Input Sprag
Solid Stator Sealing Rings
Solid Input Shaft Sealing Rings
Reverse Input Drum
Ready for the Reprogramming
Accumulators and V.B.Plate Modified
ValveBody Modified and Installed w/New Solenoids
New Aluminum Deep Pan Installed
Dyno
Dyno
Pump Installed
New Molded Pistons
1-2 and 4th Ready
Reverse Input Drum
Dyno
Dyno
I did not see a collar over the splines of the input drum or new piston.There is no way that trans will hold 700 hp without that mod.A stock drum is good to maybe 450 hp max.Just my opinion.
Yeah aamco, it was just a normal rebuild... for the 3rd time, could never give me a straight answer why it kept screwing up, so I said FU. Trans would fail less than 24 hours after R&R. I got bad pump, clutches, wiring harness all for excuses multiple times. Turns out just shitty workmanship with crappy tolerances and parts. The above happened after 5 hours of highway driving.
It was well priced. Out of repect for the builder I will not disclose price.
