Tranny Wont kick down
Old 04-09-2010, 08:49 PM
redbird555's Avatar
Default Tranny Wont kick down
Ok guys just changed my OPSU the other day and Ive driven the car a few times but never really got on it. Well today I noticed that my car will not downshift into first below 40 like it should. If I press it to the floor itll go from 4-3 3-2 or just stay in 2 itll never go to 1st unless i put the shifter there in which case it will and run fine. If i floor it off a stop itll pull and shift normal and it does shift normal in everyday driving. I unplugged the pcm tonight to see if it would reset by morning but idk if thats the issue. Its not throwing an ses so i dont believe there to be any codes.Thanks for the help
Dan
Old 04-09-2010, 09:40 PM
redbird555's Avatar
Its always downshifted before and even at any speed it wont go to first unless i manually do it.
Old 04-11-2010, 08:29 AM
redbird555's Avatar
bummpp
Old 04-11-2010, 12:03 PM
Self-Admitted Scammer
ls2pontiac's Avatar
rev it up in neutral to 3000 rpm and drop it into drive
Old 04-11-2010, 07:33 PM
redbird555's Avatar
If you dont have anything constructive to add please dont post. Anyway would a transmission code trigger an ses light or is it like abs codes where it takes a special reader to see them.
Old 04-13-2010, 03:21 PM
redbird555's Avatar
bummp..... Sorry guys i wont be home and able to work on this thing till thurs I'm just looking for a good place to start. Does anyone know if theres any wires behind the intake that would make this happen? Also I noticed when punched from a stop it will shift at 5400 ish rpm according to the tach i kno its anything but accurate however the car used to always shift around 58-5900
Quick Reply: Tranny Wont kick down
