98 4l60 drives but at stoplight it bangs an clangs an wont go
Old 04-15-2010, 08:08 PM
blubu's Avatar
Default 98 4l60 drives but at stoplight it bangs an clangs an wont go
98 4l60 drives but at stoplight it bangs an clangs an wont go, you go to 1st and manually shift it, it'll go no prob, but i scared the s**t out of a old couple, i was at a redlight and it turned green and started banging an clanging an sounded like terror in there, they looked an sped off, i pulled it over and restarted it and it wont go in drive, but will go if you manual shift and it has that horrible noise between shifts, i parked it. Its stock, 125,xxx miles no stall, 4:10 geared and psi turned up.
Old 04-15-2010, 08:09 PM
blubu's Avatar
Default Z28 tranny
also there has to be internals tore all to hell and back.
Old 04-17-2010, 09:35 PM
blubu's Avatar
Default Anyone at all ? !
anyone have any ideas ?
Old 04-18-2010, 04:56 PM
FLT
FLT's Avatar
I think you have an input sprag that has failed. I'm sure from what you have described there is other damage associated with it. Feel free to give us a call if you are looking to replace your transmission. I'm sure we can build you a transmission that will suit your needs. Vince
