quick question about cooler fittings from 95 4l60e
I have a big trans cooler because it gets hot here. I want stainless flexible lines made to run from my LT1 4l60e to my cooler, just to keep leaks away and have it look nice. What size and type of fitting are on the cooler lines coming from the transmission? I'm not talking about the brass insert that screws into the transmission but the actual fitting on the double flared steel lines that go into that compression fitting. They are the same as the straight brake lines you can buy at any auto store but I forget the size.
I have this.
http://www.bmracing.com/PRODUCTS/Uni...TU-11x11x1-1-2
