4l60e swapped to a 700r4
Old 05-01-2010, 09:12 PM
blkgagt94's Avatar
Default 4l60e swapped to a 700r4
can i take my 4l60e tranny out an put in a 700r4 in it cause sumthings up wit my 4l60e only thin gi gota do it hook up reverse lights an kick dwn but will it work?
Old 05-01-2010, 11:04 PM
1989GTA's Avatar
For one thing you would have to find a way to hook up the TV cable on the 700R4. If you don't you will eventually burn out the transmission. Plus you would have to swap over the VSS drive/system. How would you lock up the torque converter? I don't know how the car computer will react. Just some thoughts as I'm sure others will chime in with more knowledge than I have.
Old 05-02-2010, 01:47 PM
blkgagt94's Avatar
motor is a lt1
Old 05-02-2010, 01:48 PM
blkgagt94's Avatar
an has shift kit in already
but how would i disable check engine light if i dnt have tranny wires pluged in
Old 05-10-2010, 10:48 PM
bowtiee's Avatar
Does anyone know of a 4L60e tail housing (6 bolt pattern) with the cross member mount located to the rear of the housing? Thanks for any info.
Sam
