SS4000 Owners post your 60' times
Old 05-05-2010, 09:11 PM
kevins2000LS1's Avatar
Default SS4000 Owners post your 60' times
got a SS4000 and 1.64 is my best with lower control arm and relocation brackets and BMR adjustable torque arm. Thinking about some subframe connectors. Please post your best 60' and suspension mods and any recommendation's!
Old 05-05-2010, 10:04 PM
GregWS6&z28's Avatar
spraying just out the hole, LCA's, relocation brackets, COMP adj rear shocks, QA1 fronts, 3.70 gear, SS4000, Midwest TA, 28" Mickey Radials
Old 05-05-2010, 10:49 PM
LS1nut377's Avatar
with stock internals and terrible track and awful D.A.- 4600 1.70. I hope to cut into the 1.5's this year! i love my SS4000!!!!!!!
Old 05-05-2010, 11:11 PM
Formula_LS1's Avatar
1.58 with stock internals...only suspension mods are LCA's, SFC's, and a drag bag
Old 05-06-2010, 06:17 AM
Detroitmuscle's Avatar
1.53 60'
car weighs 3710lbs with driver and runs on 255 MT drag radials. suspension mods are torque arm, lcas and brackets, phb.
Old 05-06-2010, 11:48 AM
SSmoken's Avatar
dont have a yank, but ptc 4000. 1.64 with only suspension mods being lowering springs.
Old 05-06-2010, 05:58 PM
Subframes are next. I have stock internals and 3.23's. Hoping to find some 1.5???
Old 05-06-2010, 07:04 PM
Formula/LS1's Avatar
Went from 1.97 60ft. to 1.65 with SS4000 and M/T DR's.
Old 05-06-2010, 07:38 PM
You should be a 11 second car. sounds like ours runs about the same i have 3.23's. and went 7.60 flat and 12.002 1/4. Your 7.59 should put you at a 11.999!!!
Old 05-07-2010, 06:24 AM
HaulinHawk's Avatar
1.52 60fts,bmr lca,reloc brackets,tq arm,r sway.
Old 05-07-2010, 12:46 PM
01trans am's Avatar
1.7's is the best I have got out of the set up in my sig.
Old 05-07-2010, 03:18 PM
Hoping for the high 11's !
Old 05-27-2010, 10:44 PM
got to do something to get these 60's down on my ride
Old 05-28-2010, 10:31 AM
BlackWS666's Avatar
1.4213 60ft<-----SS4000
Old 05-28-2010, 10:56 PM
suspension mods and rearend??
Old 05-28-2010, 11:08 PM
TXZ28LS1's Avatar
man i really wanna go from a 3200 to the SS4000 stall.
Old 05-28-2010, 11:29 PM
BlackWS666's Avatar
All rod ended Burkheart LCA's, relo brackets, panhard. Spohn torque arm, and drag bar. Stock springs cut 2 coils off, QA1 shocks. Rearend is a moser 12 bolt built by Burkheart w/ 3.90 gears. Tire is a 275 60 MT DR. Car also weights 3065 with me in it.
Old 05-29-2010, 09:51 AM
LS1 BU's Avatar
1.42 60ft on 275/60/15 et radials first time out.
Old 05-29-2010, 10:01 AM
99corvette's Avatar
You will love it. I had a TCI 3200 and i was cutting 1.70s 60 foots. Then I put a TCI 3500 and was cutting 1.61s. Then i put a PTC 3800 and was cutting 1.58s. I just put in a SS4000 this weekend hoping to go to the track tonight and see what it does. My car is cam only too! I got a SMALL cam headers and 3.73 gear. All stock suppension. Car weighs 3400 with me in it. Car put down right at 400 hp. So far my best is
1.58 60 ft
7.36 1/8
11.55 1/4
93mph
Old 05-29-2010, 01:25 PM
BAMALS1's Avatar
Nice numbers guys, I plan on purchasing this converter soon. My best 60' is a 1.69 with a PTC 3600. I hope to improve on that with the Yank SS4000.
Quick Reply: SS4000 Owners post your 60' times
