ATI Tree master non-lock up 8" race converter
Old 05-06-2010, 08:00 PM
BOLO's Avatar
Default ATI Tree master non-lock up 8" race converter
Anyone utilizing this converter with their racebuilt 4L60E? I know it's a non-lock up. What has to be done to the trans to make it work? Any input is appreciated. Thanks
Old 05-06-2010, 09:35 PM
BOLO's Avatar
No one? Any one? Someone?
Old 05-07-2010, 07:34 AM
72blownvert's Avatar
To turn a 60e to a non lock up all you need is a non lock up valve that goes in the pump & take the ball & capsule out of input shaft.Make sure you put a trans temp gauge to see fluid temp as a non lock up tends to run a little hotter.Why do you want to turn it into a non lock up?
Old 05-07-2010, 04:58 PM
Circle-D's Avatar
We have a 230mm converter we are making for the 60e. It has a stall range of 4500-5500. We can make it lock-up or non lock-up.
The reason to go non is to save weight. If it is a track only car and you never use it, the might as well take it out.
Chris
Old 05-07-2010, 05:47 PM
LS1Tech Sponsor
FTI Converters's Avatar
ditto for chris. we build an 8" full competition converter for 60e's as well.
Greg
Old 05-07-2010, 07:02 PM
FLT
FLT's Avatar
Transgo makes a valve kit for what you are looking to do. Here is what it says on their page.
4L6-CCV 4L60E 93-04 Converter Conversion Valve: Corrects converter flow to primary pump area so converter will stay full under high load. Use with non lockup converter.
Hope this helps. Vince
Old 05-07-2010, 07:26 PM
BOLO's Avatar
Thank you all, Sponsors/Vendors. That's what I'm looking for.
