What is needed to make custom transmission lines
I have a 02 Trans Am. The way the factory transmission lines route it goes right through my procharger belt. I would hate to see what the belt could do to the lines if it broke, but my bigger issue is that everytime I change a belt for my procharger (been trying different pullies) I have to undo the lines to get the stupid belt off.
I would like to make or have made some transmission lines out of push lock fittings and hose if possible that goes straight to the cooler instead of routing under the oil pan and crank pulley, then back over.
Has anyone done this and if so what did you use and some pointers would be great. Thanks
Edit: If there is a thread with some usefull info. on this already please point me in the right direction. I couldn't find anything.
stainless steel line would work for me too. I guess my question is more or less how to connect the line to the piece that inserts into the transmission.?.?
Are people just cutting the line a little ways from the transmission and just hose clamping the line to whats left of the factory line or is there a better way?
No do not cut the lines then clamp hose over top of them. You will have to replace the fittings on the trans to accomindate the hose.
Do you have a part number for the fittings that go into the trans that allow hook up of an a/n fitting?
Yeah as long as you flare the ends, that would work. I was saying no dont just cut the lines then place a hose over them (without a flared end).
That kit looks pretty nice, you could do the same with some new fittings and braided hose, and probably for cheaper.
The 1/4 NPT fittings will work, Summit Part Number SUM-220647B then use 45 or 90 degree fitting SUM-220706-B or jsut go with SUM-220751.
Or you could just use 1/4 NPT to 5/16 (or 3/8) hose barb which is what I am using.
