anyone running a th400 and 3.23 gears
Old 05-09-2010, 11:02 AM
SPRAYED Z's Avatar
Default anyone running a th400 and 3.23 gears
Its a lt1 car with th400 and 3.23 gears, How many people have this setup on their cars? how well or dont it run?
Any proven data out their?
thanks
Old 05-09-2010, 06:03 PM
Blue85350's Avatar
i have a turbo 350 and 3.23s in mine(daily driver), the th350 has deeper first and second gears, and honestly i'd go with a deeper rear gear. just not enough multiplication in first.
Old 05-09-2010, 11:16 PM
robsquikz28's Avatar
Their are a few peeps in here but I think you might have to do a search.
Old 05-09-2010, 11:20 PM
johnrobbins's Avatar
There are a bunch of people that run that setup. Look around and you should find some without any issues.
Old 05-09-2010, 11:23 PM
1BAD_LS1 Tunes's Avatar
i currently am running 3.70 with a th400 in my DD... i have some 3.00 gears to go into the 9" sitting here... cant wait to get them in, just have to get the time.
You'll be fine....
Old 05-10-2010, 06:52 AM
forcd ind's Avatar
its not so much trans and gears, but that the engine (cam, tire size, rear ratio, etc) converter are all setup to work together-change one item and your stall will change-i ran a 400 with those gears, but installed a 2.75 gear set in the trans, gave me a little better take off, but in 3 rd i still had some good cruising RPM,s
Old 05-11-2010, 02:33 PM
SPRAYED Z's Avatar
Ok, so If Im using a 383, ported heads,intake and cam, shifting at about 67-6800rpm. 26" slicks will be used with a 3.23 gear. I would like to use the th400 trans but what stall would be the best bet. Im also spraying the car with a minimum of 200?
thanks
Old 05-12-2010, 09:05 PM
SPRAYED Z's Avatar
anyone else
Quick Reply: anyone running a th400 and 3.23 gears
