banging the REV
Old 05-13-2010, 05:31 AM
rouchiemanz28's Avatar
Default banging the REV
I have a performabuilt trans stage 2 that bangs the rev every time going to third gear wide open. whats the problem?
Old 05-13-2010, 08:08 AM
01ssreda4's Avatar
Tuning I would bet.....
Old 05-13-2010, 09:40 AM
LS1Tech Sponsor
performabuilt's Avatar
Your shift command time may be too close to the limiter I would say this would be particularly true if it shifts fine just off WOT remember that while electronics are instant hydraulics are not typical RPM needed to complete a 2-3 shift from comand to actual is 200-500 rpm depending on many variables ranging from rear ratio to car power levels also spray changes this also.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 05-13-2010, 10:23 AM
twitchtwice's Avatar
yeah i had that problem until i messed with the tune.
