LS1 w 4L80e will i have tcc lockup?
ive got a 97 4L80e
and 4L80e stock rebuilt converter
im looking for a flexplate solution
so far the best i found is
flexplate 57
spacer 40
bolts 5
total $102
at crateenginedepot.com
and can i have manual valve body
and torque converter clutch lockup switch?
tcc lockup w 4L60e and YankSS4000 would unlock for no reason and stay unlocked on the damn highway costing me fuel and trans fluid
i gotta have a manual lockup switch this time around
flexplate 57
spacer 40
bolts 5
total $102
looks like TCI has manual shift, lockup, protree manual reverse for ~$650 damn!
rossler has protree manual reverse also
but is it true you must use their deep pan?
does it have tcc lockup?
planned on getting transgo manual for $230
but then $300 install might as well get a better vb w transbrake
does transgo have lockup?
i know it has no transbrake
what are you guys doing about this?
Gingervitis Addict
I'm using a brake that works with automatic or forward manual. I know its a lot faster than that standard Rossler (haven't compared it to a rossler "pro tree", although I'm pretty sure its faster than that one too, and I haven't done any internal mods for a brake yet).
