what flywheel
Old 05-30-2010, 11:21 AM
drew240's Avatar
Default what flywheel
what kind of flywheel do i need for a TH350 on an LS1? im buying the trans from a friend with a 4000 stall converter and i need to know what kind of flywheel to order.
Old 05-30-2010, 12:24 PM
01ssreda4's Avatar
Not trying to give you a hard time buts its a flexplate.
Old 05-31-2010, 06:49 AM
forcd ind's Avatar
you can use the GM one for a 6.0 with a 4l80e-spacer, flexplate, bolts-ck the converter bolt pattern to the flywheel
Old 05-31-2010, 11:42 AM
drew240's Avatar
ok thanks, its my first ls1 build and someone told me i needed a different flywheel. now i know, thanks.
