cooler mock up....pics
well i've been taking my time on this one.. my dd took a dive south as well so ive been dd the z for a month and ahalf now...sure doesnt help either...i mocked up the cooler and took some pics.. let meknow if you guys see anything wrong with it...
just incase its not clear from the pics, its mounted on the passenger side of the condenser.its bolted to a metal plate that doesnt vibrate.
I think its fine as long as the center slants are facing upward. Not the big fins but the passages in between them. Notice while looking at the front of the cooler, depending on which whay you tip it, left or right, you can either see through it or you cant. Remember the air is gonna be coming from under the right side of the cooler and traveling right to left based on the way you have it mounted. I would make sure this is the way the cooler air ducts are formed. If it isnt, I would swap it around.
