4l60e Tranny bolt stripped HELP!!
Old 06-03-2010, 10:51 PM
SSHAWK's Avatar
Default 4l60e Tranny bolt stripped HELP!!
Like the title says
My 2000 ws6
One of the tranny bolts stripped (rounded bolt head) and it will not come out. I need some tips on how to remove this with out messing up the block or bellhousing.
Old 06-04-2010, 08:17 PM
Richard 72 GMC's Avatar
If you can get to it with a drill, try an easy out
Old 06-04-2010, 10:02 PM
SS SLP2's Avatar
Which one?
you may drill a hole in the floor of car and get to it.
Sears sell a special socket that you drive on ( it cuts in as you turn left to remove bolt) and use a extencion and ratchet.
If all fail you may need to drop enguine and trans as a unit
good luck, Johnny
