How to get bellhousing bolt out?
Old 06-06-2010, 05:28 PM
TheTransporter69's Avatar
Default How to get bellhousing bolt out?
Hi, I have a 94 Trans am and i have all the bellhousing bolts out except one which i can't seem to figure out how to get anything to work on it.
Here is the Pattern
0 0
X 0
0 0
( second one up on the drivers side)
The one with the X is the one i can't seem to get, the chassis is just to close to the bolt. Anyone else have this problem?
Old 06-06-2010, 06:27 PM
dnkynrbk's Avatar
The bolt that bolts the bell onto the motor.
Old 06-06-2010, 08:17 PM
i dont think so, the passenger side header was hitting the bell housing, but i loosened that up but the area it is in just seems to tight. Very frustrating since its the last bolt also.
Old 06-06-2010, 08:43 PM
dnkynrbk's Avatar
I use a ratching wrench or us a wobble set of ext. with a knuckle joint.
Which bolt is it. Your diagram on here didnt work.
Old 06-06-2010, 09:06 PM
i thought about a ratcheting wrench with a bendy handle, that's about all i haven't tried yet. Its the second one up on the drivers side, or the middle one of the three on the drivers side. i have swivels and i bought a 14 mm swivel socket last night, it worked for some but the socket just ends up hitting the chassis, i think when i get the tranny out im gonna see if i can dent it up to make more room cause this is a real f*cker!!!! all i got to fit so far was a open end wrench but when i start torquing it, it just starts to slip. I dont know if its just my car twisted up a bit or if this is how they are all designed?
Old 06-06-2010, 11:04 PM
8595transam's Avatar
Only bolt I ever have trouble getting to is the one on the very top on the driver side. A swivel joint and lots of extensions and it comes right out.
Old 06-07-2010, 08:20 AM
like i said swivels hit the car body.
