Question on 4l80e yoke
Old 06-10-2010, 08:27 PM
Black_98Z's Avatar
Default Question on 4l80e yoke
Can you use the stock 4l80e slip yoke with the stock t56 driveshaft? The u-joints look the same size. I see a lot of info about getting a th400 yoke but I have the one that was on the 4l80e. Looking to see if I can put it on the stock t56 driveshaft.
Old 06-10-2010, 10:28 PM
Gingervitis Addict
slow67's Avatar
yes you can, with an adapter u joint (depending on the size of the joint in the yoke).
Old 06-17-2010, 07:55 PM
Black_98Z's Avatar
FYI the stock 4l80e yoke worked with the stock driveshaft with a conversion u-jonit at napa #447.
