trans cooler fan
Old 06-17-2010, 12:10 AM
DemonInside's Avatar
Default trans cooler fan
im looking for a switch 12v so my trans cooler fan is on whenever the key is on, i wanna ditch a switch. any help would be great thanks
Old 06-17-2010, 08:41 AM
01ssreda4's Avatar
Get a cheap multi-meter or test light and probe the fuses under the hood.
Old 06-17-2010, 11:42 AM
Choppers's Avatar
I want to see a pic of the fan installed on the cooler when you finish because I'd like to do the same whenever I stall my car or maybe cars.
Old 06-17-2010, 02:30 PM
i feel like such a newbie but i never do much with wireing stuff just assembling motors ect. i origionally tapped into the horns but it wasnt switched at the fuse block because the minute i hooked it up the fans were on
Old 06-19-2010, 01:11 AM
BenLaz's Avatar
just use a relay.... hook up pin 85 to something ignition switched 86 to ground, then wire your 30,87 and 87a accordingly to power the fan.
Old 06-21-2010, 10:10 PM
id rather not buy extra parts really
