Auto Trans Mount
Old 06-21-2010, 07:42 PM
J-Bru-Ha Z-28's Avatar
Default Auto Trans Mount
Does anyone have a part number for an auto trans mount? Apparently none of the parts stores carry a mount for our cars???
I wanted to stick with a stockish trans mount as oppose to a poly since my motor mounts are still stock, and I have heard bad things about using a poly trans mount with stock motor mounts, issues with the bell housing cracking.
Anyone have advice???
Old 06-21-2010, 07:54 PM
SSPerformance's Avatar
a poly mount with stock motor mounts will be fine
Old 06-21-2010, 08:45 PM
01ssreda4's Avatar
^^^it may or may not. What it does do is put undue stress on the tailshaft of the trans. Dont tell people it will be fine. Are you gonna buy him a new tailshaft if his cracks?
Old 06-21-2010, 08:47 PM
01ssreda4's Avatar
OP, I believe the LT1 trans mounts will work. Im not 100% sure about that though. Take an old mount in and verify this before you purchase.
Old 06-22-2010, 01:36 AM
'91firebirdformula's Avatar
i'm thinking he will be ok. are you saying the extra vibration will put more stress on the tailshaft HOUSING? i think if he can get the car to launch hard, that the poly mount would be the last thing that i would blame a cracked tailshaft housing on.
Old 06-22-2010, 11:22 AM
I had heard of issues with the bell housing cracking since the motor is still on softer mounts than the trans would be with a poly trans mount, forcing the bell housing to constrain the motor's movement.
My biggest issue is the nearly $100 the sealership wants to charge me for the new OEM trans mount.
Like it has been suggested by 01ssreda4 does anyone know for sure if a trans mount from a earlier/different model that uses the 4L60E trans would work?
Old 06-22-2010, 11:27 AM
01ssreda4's Avatar
LT1 mounts are like $8. Might be worth a shot. The trans is the same in LT/LS cars (basically anyway)
Old 06-22-2010, 11:33 AM
Another internet jerk off... It will be fine I have ran them. In a few cars
Old 06-22-2010, 12:13 PM
Joshiedoom's Avatar
Ive run one for a long time...
Old 06-22-2010, 01:41 PM
This is exactly what I was hoping someone was going to be able to tell me...I'll give this a try first...its a lot better than what the the dealer was gonna hit me for.
Thanks for the help guys!
Old 06-22-2010, 01:48 PM
Joshiedoom's Avatar
They are like 6.73 at oreillys.93-02 v8
