Tuned then tranny stopped working
So i had my car tuned, a mailorder and the list below is what was done,
Claibrated MAF, adjusted the parmimters in: throttle cracker, PE table, both VE tables, both Spark Tables, base running airflow, throttle follower tables, part throttle shift tables, full throttle shift speed tables, full throttle shift rpm tables, force motor current tables, desired shift time tables, shift pressure tables, tcc duty cycle tables, torque reduction tables
Would anything here raise a flag as to problems, i am broke and can not afford a new tranny so i am heartbroken
All of what you listed raises a flag if the tuner was a hack. If it shifted fine on the previous tune, you need to go back to that tune. I suggest not driving it. If the tranny settings are that hacked, driving it could be doing damage. How long have you had the mail order tune? It never shifted right after the new tune?
Did it downshift to 2nd and slip or was it stuck in second when you floored it? if it shifted fine for 20 minutes i hate to say it but it may be mechanical, atleast thats where id be leaning. check your fluid as well...
i believe it is mechanical because the day after i swapped the fluid and filter to see if the filter was plugged, the magnet in the drain pan had quite a bit of metal stuck to it, just small metal dust.
i brought it to gm and the computer read that pressures would not raise high enough to shift even when the tech manually tried to raise them with the computer hooked up.
it shifted to second then would redline and not shift, then got to the point where i couldnt get out of first and was undrivable as i was scared of doing more damage so i had it towed.
