Will a V6 4L60e bolt to an LS1 if I change the bell housing?
Old 06-29-2010, 12:34 AM
Strobes's Avatar
Default Will a V6 4L60e bolt to an LS1 if I change the bell housing?
I just started swapping an LS1 into my car. I did some searching but couldn't find a specific answer. Is the v6 4l60e the same as the ls1 just a different bell housing? I'm really tryin to save as much money as I can and was just wondering if I could swap it out or buy a whole new transmission
Old 06-29-2010, 12:45 AM
Ellsworth's Avatar
pretty sure it wont work because the input shafts are different.
I might be talking out my *** too. so id suggest calling a tranny Sponsor ----->
Old 06-29-2010, 09:36 AM
Choppers's Avatar
Will not work.
Old 06-29-2010, 09:45 AM
bad_408_vert's Avatar
OP: It wont work.
Choppers: please a make a build thread when you are done.
Old 06-29-2010, 10:00 AM
Choppers's Avatar
Originally Posted by bad_408_vert
OP: It wont work.
Will do. Already have most everything except my cam and time to do it.
Old 07-09-2010, 04:48 PM
Slvr00Bird's Avatar
Input shaft and servo are different.. if you search, you'll find the specifics, but that's all I can remember.
Old 07-10-2010, 11:19 AM
B2E2RUN's Avatar
depends, here are the specs. http://www.novak-adapt.com/knowledge/4l60e.htm
Old 07-10-2010, 07:44 PM
1quickirocz's Avatar
I think if you get a bell housing,complete input housing, pump, and possibly a servo from a V8 4l60e it will work.......but i guess by that point you will have a complete V8 trans so no need to convert it haha. I would just look for a v8 one to use.
Old 07-27-2010, 07:08 PM
Strobes's Avatar
Yeah I just want to buy a V8 trans for my LS1 swap so I can finally get it done. However my dad's convince if I just get a bellhousing and torque converter and such we could use my V6 trans...I don't know what I should do...guess I need more confirmation.
Old 07-27-2010, 07:23 PM
Jays_SSZ28's Avatar
I have a LS1 4L60E and a V6 4L60E.
The differences:
Bellhousing.
Converter.
Input shaft/drum.
Pump stator tube.
Second servo.
Forward accumulator spring.
4th accumulator spring.
I'm sure theres more calibration wise but nothing a shift kit couldn't fix. Even the holes in the seperator plate were very close between the two to probably work fine with a V8.
The following users liked this post:
05silveradols1 (07-13-2021)
Quick Reply: Will a V6 4L60e bolt to an LS1 if I change the bell housing?
