confusion on stall converters
Old 07-12-2010, 08:18 AM
demonpixel's Avatar
Default confusion on stall converters
A little confused about stall converters -
I've read many posts that say if you have an automatic trans, getting a 3200-3600 stall is a great mod.
But then I've read a lot of posts that say if you get a stall that high, but you drive under the stall number, your transmission will heat up without a transmission cooler. This heat will make the fluid break down, and your transmission will eventually go out.
Which is correct? A great mod or a dangerous one?
Old 07-12-2010, 10:21 AM
SS SLP2's Avatar
A great mod, get a cooler with a fan on it (100-120.)
if running under lock up speed (45-50 mph) trans will heat up but cooler should keep it safe
you will enjoy stall , and wonder why you did not do it sooner
I ran yank st 3500 for 8 years now yank ss 4000, may go to a 4400,
I am cam/gears/ boltons
Johnny
Old 07-12-2010, 11:35 AM
demonpixel's Avatar
Cool SS, what trans and gears? 4L60e? 3.70?
Old 07-12-2010, 11:58 AM
SSmoken's Avatar
just get a cooler and you will be fine. dont go any smaller than a 3600 stall. they just arent as much fun.
Old 07-12-2010, 12:01 PM
Wimimc's Avatar
i planned on getting a stall as well so i should think about this too.
where is a good place to get a cooler?
Old 07-12-2010, 12:03 PM
NVR_SPDS's Avatar
Yup, like was said. It is basically mandatory to put a bigger/better cooler in when doing a stall. Hell, even before the stall, a good cooler wont hurt!
Old 07-12-2010, 01:57 PM
SS SLP2's Avatar
as stated " Hell, even before the stall, a good cooler wont hurt!"
running 4l60/ vac mod( been into several times because of hot lapping-heat) just added another cooler/fan
running 3.73/10bolt/locker for now, 4.10 /9"/locker waiting on the side
Johnny
Old 07-12-2010, 02:15 PM
Camaro Junky's Avatar
Get a cooler bro. Frank at Performabuilt says if you don't put one in after a Tranny purchase it will void your warranty. So they have to do something good lol
Old 07-12-2010, 04:04 PM
demonpixel's Avatar
Would it matter if the trans was a 4L60e or a TH400? Or the same principles apply?
Old 07-12-2010, 04:43 PM
demonpixel's Avatar
I've heard good things about the B&M 70264.
Old 07-12-2010, 10:37 PM
SS SLP2's Avatar
"4L60e or a TH400? ....the same principles"
Yep
Johnny
Old 07-12-2010, 11:01 PM
skat's Avatar
Yea you will be fine if you get a good cooler like the B&M listed above. And it would also be a good idea to get a good tranny temp gauge too. I have an Autometer elec. and I like it.
Old 07-13-2010, 08:16 AM
demonpixel's Avatar
Sounds good guys, thanks for all the responses!
