What size bolts for bellhousing/tail shaft?
Old 07-14-2010, 08:40 PM
BigAls87Z's Avatar
Default What size bolts for bellhousing/tail shaft?
Hey, Im in the middle of an LS1/4L60E swap into my third gen, and I have a trans, but its in pieces. I wanted to know what type of bolts I need for the bellhousing into the trans, the tailshaft into the trans, and what size bolts for the bellhousing to the engine are.
Thank you guys very much!
Old 07-15-2010, 05:51 PM
Jays_SSZ28's Avatar
Bellhousing to engine: M10x1.5x40, 13mm hex.
Tailhousing to transmission case: M10x1.5x27, 15mm hex.
Bellhousing to trans case: M10x1.5x45, T50IP (torx plus)
Bellhousing to transmission bolts are probably GM only. I've sold a set on ebay not long ago, there are some sets on there now for around $15.
Old 07-16-2010, 12:40 AM
BigAls87Z's Avatar
Thank you Jay. I called GM on the tail housing, and picked up a few 10.9 bolts today. That should do the trick.
Ive seen the tranny to housing bolts on ebay, but they are 40 bucks or so.
Old 07-16-2010, 01:20 AM
Jays_SSZ28's Avatar
Damn, I sold a set for $15 http://cgi.ebay.com/ebaymotors/ws/eB...m=220603387848
Could have sworn I seen others for around that price.
Quick Reply: What size bolts for bellhousing/tail shaft?
