Which is the best way to launch a 3,600 Stall Converter?
I have a SS Yank 3,600 converter being installed this tuesday and im just wondering what would result in a better 60ft time,flashing from idle or footbraking as much as the tires can hold and then stepping on it?
I had a 3,400 Vigalante in a 87 Grand National and would have to get the boost up prior to launching..
So i just wanted to see whats best for these type of cars...
Thanks for all of your thoughts in advance...
Launch
Thanks again to all of you. My converter was installed today,so im taking a long ride around Florida tomorrow because the card that came with the converter said not to launch hard until i have driven 150 miles on the car i guess these require a breakin period?
And as long as the rain holds off i will be at the track this friday nite...
I will update you hopefully with Great news...
Thanks again
Thanks again
Thanks again
Thanks again
I have tried both with my Circle D and I have gotten a little better (very slightly) results from mashing the pedal from an idle.....every car is different so it is best to just try both and see what works for you/your car
