Weird noise
Old 08-01-2010, 06:25 PM
LS1 bird's Avatar
Default Weird noise
I got an 02 formula and I have a weird noise coming from up front by the tires on both sides.It's sounds like a tink tink noise.Sound is stronger on the passenger side than driver side.The tink tink noise sounds louder towards the bottom of car.With a load on the car and off at idle is still there.It gets louder as u give gas while driving.The car does have a fti 3600 stall and a transgo shift kit.Have check oil not milky checked tranny fluid and it's pink wit very little metal flaking.Due to clucth residue.Any thoughts on whats goin on will be much appreciated.
Old 08-02-2010, 07:00 PM
LS1 bird's Avatar
I think it's my drive shaft seal.Will know more tmw
Old 08-02-2010, 07:39 PM
Badazz 97 TA's Avatar
metal flaking doesnt sound good. Might wanna pull the pan and see if its any worse. If its showing up on the dip stick then theres probably a lot in the pan.
