converter wont unlock
Old 08-01-2010, 07:50 PM
klawittera's Avatar
Default converter wont unlock
i have a 93 t/a and the torque converter wont unlock. I was wondering if anyone had any ideas what could be the cause.
Thank you
Old 08-03-2010, 12:33 PM
LS1Tech Sponsor
FTICONVERTERS's Avatar
hung lock up valve in the pump? bad solenoid? bad converter?
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 08-06-2010, 08:58 PM
klawittera's Avatar
I was going with the cheapest fix first, so i already replaced the TCC solonoid and thats not it, so it looks like i'm going to be disassembling my pump next.
Old 08-07-2010, 08:47 AM
Detroit Gearbox's Avatar
When you removed/replaced the lu solenoid, did you push upward on the lu valve (located under the tcc solenoid) to see if it was stuck or moving freely. Its rare, but I have seen the springs break, and a small piece of spring get caught in the valve.
93 is pretty old.... fluid is still in good condition?
Old 08-07-2010, 02:47 PM
tug686spd's Avatar
Just had the same problem but mine ended up being the soleniod. I would rule out electrical problems first. With the transmition unplugged it should work in D (third gear only) and reverse. If the transmition works unplugged then you know you have an electrical problem somewhere.
Old 08-10-2010, 09:15 PM
klawittera's Avatar
I unplugged it, and sure enough, it is still not working. I will have to take a look at that valve this weekend and see if its stuck. I appreciate the tips.
thanks
