2.73 Gears and 3600 Stall
Old 08-04-2010, 10:48 PM
Gaunt's_Girl's Avatar
Default 2.73 Gears and 3600 Stall
I'm looking to get a 3600 stall. How much impact would changing 2.73 gears to 3.73 gears have after the stall?
I realize some stalls are built on gear ratio, but just wanted to know in general.
Thanks!
Old 08-04-2010, 11:09 PM
hitmanws6's Avatar
from my understanding the 2.73s will make the stall very loose, the 3.73s will make it nice and tight
Old 08-05-2010, 12:39 PM
01ssreda4's Avatar
3.73s will help you get moving
Old 08-06-2010, 12:23 AM
Yeah, I actually think I might do 3.73's then a stall. Just trying to get more info. Thanks for the input!
Old 08-06-2010, 08:13 AM
dlk1950's Avatar
When my car was bone stock with 2.73s best 1/4 I could get was 14.7,put 3.73s in and got 14.2 then put in Yank SS3600 and got 13.8s.
Old 08-10-2010, 08:12 AM
gyrene2003's Avatar
go 3.90s-4.10, then u will really be woken up!!!
Old 08-10-2010, 08:19 AM
Tyler_PinkertonZ28's Avatar
The first thing I did to my car was change out the 273's to 373's and it made a huge difference. From what I have been told, I would spin tires more with the 373 gears, but I think that I actually spin less. My next step is a Circle D pro series converter.
Old 08-10-2010, 08:34 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Also to mention IF you have not, you can have the TQ management reduced/removed and that will make another dramatic difference as well.
Old 08-10-2010, 08:37 AM
blk/slvr02ss's Avatar
3:42's are the best all around gear for a A4.
Old 08-10-2010, 10:26 AM
How do you remove the TQ management? Is it done through computer tuning or going inside the transmission?
Old 08-10-2010, 10:30 AM
Colonel's Avatar
Going from 2.73s to 3.73s will make a bigger difference with a stock converter than with a higher stalling converter. You might knock off a half second or more if you have a stock converter. However, if you already have a 3500 stall, for instance, your gain by changing gears may be only 2 tenths.
You'd be amazed what you can do with 2.73s and a 3500+ stall converter.
The nice thing about the 3.73s is how much it'll "tighten" up the part throttle feel of a loose converter.
The 3.23 gears with TCI 3500 stall I have are a great street/strip combo, IMO.
Old 08-10-2010, 10:31 AM
Colonel's Avatar
Thumbs up
Yes, it's in the programming.
Old 08-10-2010, 10:35 AM
Ok, I will ask the guy doing my tuning to remove it when he tunes out the EGR and AIR codes.
Old 08-10-2010, 01:52 PM
LS1Tech Sponsor
FTICONVERTERS's Avatar
I would change gears and the converter and you will see some tremendous gains. if I were going to keep a 273 gear then I would configure the converter for that . the converter needs to be configured for the entire combination.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 08-11-2010, 06:23 AM
forcd ind's Avatar
a set stall is based on engine, weight, cam, rear, etc-change anything, stall changes
Quick Reply: 2.73 Gears and 3600 Stall
