LS..... Coan TH 400/ TH 350 Converter
Old 08-05-2010, 05:58 PM
Fast 2010's Avatar
Default LS..... Coan TH 400/ TH 350 Converter
Not sure if ill get booted for putting this in the wrong section or not. Had Coan build me a Converter for the LS motor to fit either the TH400 or the TH350. Tripple disk....3400 stall.... never used. Pulled the plug on the project... just trying to get a little back out of it. $650 plus shipping OBO. (Michigan) 989-397-0261
Old 08-06-2010, 01:19 PM
BanditDave's Avatar
Is this a LS Conversion Converter or a standard converter that would work with say a SBC? Reason I ask is if this is an LS Specific converter then i will need to get a different flexplate. Right now I have a LY6 flexplate with the spacer, etc...
Thanks,
Dave
Old 08-08-2010, 11:44 AM
Detroit Gearbox's Avatar
Unusual combination.
must be for th350 lock up only.
They do not make a 400 lock up (you did say it was a triple disc)
Post up the part # stamped in it.
Quick Reply: LS..... Coan TH 400/ TH 350 Converter
