TH400 and gears for the street/highway - LS1TECH
Automatic Transmission 4L60E | 4L80E | TH350 | TH400 | TH2004R | Powerglide | Converters | Shift Kits
Thread Tools Search this Thread
Old 08-11-2010, 08:05 PM   #1
IT_SS's Avatar
Default TH400 and gears for the street/highway
I wanted to get a general idea of what gear are being ran with street/strip application and TH400s. This is for a boosted car, so I'm looking for a good cruising/racing gear.
thx in advance
IT_SS is offline   Reply With Quote
Old 08-11-2010, 10:37 PM   #2
dnkynrbk's Avatar
3:73 is a good gear for highway and strip thats what I have in my car. I have a buddy with twin turbos and he has the same gear running a 28inch tire.
dnkynrbk is offline   Reply With Quote
Old 08-11-2010, 11:51 PM   #3
Packy's Avatar
3.73's aren't too good for the highway at all. They work great for the 1/4 mile but not on the highway. At least that is how it is with 27" inch tires that I have. I would think that 3.54's or even 3.08's might be better.
Packy is offline   Reply With Quote
Old 08-12-2010, 05:30 PM   #4
supermouse4's Avatar
I would not go with a gear ratio higher than 3.23, 3.08 is a good gear ratio for highway driving with a TH400, depending on what your tire height is.
supermouse4 is offline   Reply With Quote
Old 08-12-2010, 06:17 PM   #5
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I've been running 4.11s with my TH350 and 27" tires for over two years now.
Z28/2002 is offline   Reply With Quote
Old 08-12-2010, 06:20 PM   #6
StreetSilverado's Avatar
I vote 3.73's
Any transmission without overdrive isn't good for MPG anyway, so you might as well throw that out.
StreetSilverado is offline   Reply With Quote
Old 08-12-2010, 08:14 PM   #7
Z28/2002's Avatar
My car is a 11.3:1 346, PRC heads, MS3 and has a 750 carb and it only used 3 gallon of gas on a 50 mile trip. I figured it would have been worse but I was shocked when I put gas in it before I headed home
Old 08-12-2010, 08:47 PM   #8
I drove a 42 mile round trip with my TH400 and 4.33's and used about an 1/8th of a tank, wasn't too bad considering..
Old 08-12-2010, 09:31 PM   #9
MASS seller approved
smok'nZ's Avatar
if its boosed i would post in the fi section
smok'nZ is offline   Reply With Quote
Old 08-13-2010, 09:24 AM   #10
trans2000am's Avatar
id go with a 3.50 or below you want some load on those turbos
trans2000am is offline   Reply With Quote
Old 08-16-2010, 12:42 AM   #11
I run 3.00 gears in my moser 9" with a 88mm turbo no issues at all with a TH400
AutomagicLS1 is offline   Reply With Quote
Old 08-16-2010, 07:01 PM   #12
TurboAv's Avatar
I'm using 3.46's with 26" tires. I want some 3.07's though. $600 for dang GTO gears though...
TurboAv is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Th400 gear choice Blown02Camaro Automatic Transmission 12 02-13-2013 02:29 PM
what gear for th400 loosews6 Drag Racing Tech 14 01-19-2013 09:02 AM
TH400 rear end gear?????? Trev_SS Automatic Transmission 5 10-15-2011 08:14 PM
Th400 with 4.11 gears? General_Joser Drag Racing Tech 10 09-03-2011 01:51 AM
what torque conveter is good mairen25 Forced Induction 8 04-08-2009 09:05 PM
Tags
2005, 307, 373, 400, acheter, driving, gardena, gear, gears, good, gto, highway, pontiac, ratio, street, th400
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
