4l60e oil cold
Old 09-09-2010, 05:42 PM
Seit's Avatar
Default 4l60e oil cold
I Have instaled a oil cooler big, B&M of 24K and oil pan Derale : its is for coolding the oil of my transmission and increasing the useful life of my transmission.
This transmission had Not some specification, the converter is the original from the factory.
I have bolt ons
I Have some questions:
Is good or is bad having the transmission with the oil too much cold ?
What happening when I use this transmission in winter season?
thanks!
Old 09-09-2010, 06:13 PM
coldblooded's Avatar
im lost....
Old 09-09-2010, 06:48 PM
Sweet_SS's Avatar
Are you asking, if your trans will be to cold from the trans cooler?
Old 09-10-2010, 12:29 PM
Seit's Avatar
I Have instaled a oil cooler big, B&M of 24K ant carter ventilated Derale: its is for coolding the oil of my transmission and increasing the useful life of my transmission.
I have bolt ons
thanks!
Old 09-10-2010, 01:33 PM
Jays_SSZ28's Avatar
What is ant carter?
If it gets cold where you live, run the transmission fluid through the factory radiator cooler first and then through the B&M cooler.
Old 09-10-2010, 02:02 PM
crazyelf's Avatar
I do not think I have ever heard of a problem arising from the trans temperature being too low.
Im not an expert but I think you will be fine.
Old 09-10-2010, 03:52 PM
Seit's Avatar
Originally Posted by Jays_SSZ28
What is ant carter?
Oil pan
Old 09-10-2010, 09:27 PM
senicalj4579's Avatar
Old 09-10-2010, 11:10 PM
$750 L98's Avatar
The only thing I could think of, is if you get the fluid so cold the converter is never allowed to lock up. I doubt that's possible though, it will likely at least be close, it will probably end up being a little cooler than rad temp most of the time.
