2.73 and ss3200 or ss3600
Old 09-12-2010, 03:04 PM
Z06 Steve's Avatar
Default 2.73 and ss3200 or ss3600
if I swap in a stall convertor will my cruise rpm be affected?
Old 09-12-2010, 04:47 PM
Yank's Avatar
No! converter has a lock up clutch as OEM one and will not change your cruse RPM
Old 09-12-2010, 05:14 PM
Z06 Steve's Avatar
ok great now between the two ss3200 and ss3600 and 2.73 gears would the bottom end feel too loose with the 3600? my goal is a low12 high 11 car with bolt ons but retain great drivability.
Old 09-12-2010, 05:20 PM
blk/slvr02ss's Avatar
I would go w/ the SS3600 i really dont feel a difference in the stock one and the SS3600 except when i punch it then it throws u in the seat.It will be the best money u spend on your car.
Old 09-12-2010, 05:29 PM
Z06 Steve's Avatar
what gears u running? thanks
Old 09-12-2010, 05:36 PM
Stock 3:23's and the cruising speeds RPM went down w/ the SS3600 stall and i get better gas mileage and my car w/ just bolt-on's and no weight reduction runs 11.88.
