......Trans service 2000 Z28
Old 09-19-2010, 11:06 PM
bat1's Avatar
Default ......Trans service 2000 Z28
I'm going to do this at home (car has a Automatic)
What do i need? best filter kit?
what's the best fluid?
what's the best way to drop the pan so I don't get oil everywhere
car has 90,000 and don't know it it's ever been charged
I also need to change the output seal which is leaking
what's the best way to remove the drive shaft?
Thanks for any advice!
Ed
Old 09-19-2010, 11:38 PM
Jays_SSZ28's Avatar
Best filter SPX Filtran.
Best pan gasket Fel-Pro (forgot the number).
To remove the pan get some old bath towels and/or a big pan, leave a few front pan bolts loose and take all the others out.
For the seal, set the parking brake, remove the four 11mm (7/16) bolts from the u-joint straps on the rear yoke. Pull it out. Get a National seal.
Have fun.
Old 09-20-2010, 01:00 AM
99huggerorangeZ's Avatar
Have fun.
Don't forget to mark the driveshaft with a paint marker before removing it. So it is reinstalled in the correct postion, that way you won't run into any vibration issues.
Old 09-20-2010, 11:34 PM
Knuckls'1's Avatar
What brand of fluid do you plan to use? just curious.
