Unknown Transmission Fluid Leak.... Help Please
Old 10-01-2010, 10:59 PM
mesterious's Avatar
Default Unknown Transmission Fluid Leak.... Help Please
Hey guys. I put a new stall in my converter in my car along with the biggest super cooler that B&M makes about two weeks ago. I have been having transmission fluid on my garage floor now coming from, what it appears to be, on the back of the air dam, and above on the metal part above the back of the air dam. There is no sign of fluid coming from the cooler's barb fittings or the transmission cooler lines except for it being a little wet but not from the beginning of where the hose is threaded on just in the middle of the hose. Anyone got any idea's?
Old 10-02-2010, 02:02 AM
NXZ28's Avatar
It could be fluid from when you initially unhooked the tranny cooler lines from the radiator to install the cooler. Did you cap off the inlet and outlet cooler ports on the radiator? If not, it will leak down on your lower radiator support for awhile.
Old 05-08-2011, 09:28 PM
aothepresident's Avatar
I know this is an old thread, but I have the exact same issue right now. Any other ideas or did the OP find a resolution? Thanks
