Pro Ratchet Install with M6 console - LS1TECH
Automatic Transmission 4L60E | 4L80E | TH350 | TH400 | TH2004R | Powerglide | Converters | Shift Kits
Thread Tools Search this Thread
Old 01-29-2004, 08:07 AM   #1
Formerly 4mulaJoe
LS1x2's Avatar
Default Pro Ratchet Install with M6 console
There was a post a while back asking about how to mount a B&M pro ratchet shifter or other in these cars so that it looks factory. I had posted a pic of mine located here http://torqueaddicts.com/media/my.fo...s/photo_9.html. We are doing the same thing to a friend's Z28(JT093). It was an A4 car, but he got hold of an m6 console. You can see pics here of the process. http://torqueaddicts.com/pr. It is not done yet, but the reason we had to cut was to get the shifter mounted lower. The next step is to weld a thin plate of steel over the hole from the bottom. Then just drill a couple holes and bolt the shifter down. It fits just right with the m6 console and still looks factory. Keep and eye on those sparks though. It would have been better if we had a sawzall.
LS1x2 is offline   Reply With Quote
Old 01-29-2004, 01:56 PM   #2
Whew...those sparks are killer, they also make your car very dirty. I suggest placing a large sheet or towel over your dash.
I picked up a peice of 16 gauge steel today from Lowes ($12). I am going to cut it to fit (9"x5.75"), then weld it from the bottom. Next, I'll drill the holes hole for the shifter and mount it. I'll take some pictures and post em up when I'm done.
jt093 is offline   Reply With Quote
Old 01-29-2004, 02:02 PM   #3
LS1Tech Co-Founder
Pro Stock John's Avatar
Mine with A4 insert, I'd like to find a solution for the sliding plate:
http://www.ls1tech.com/psjpics/griffinpics/griff6.jpg
Pro Stock John is offline   Reply With Quote
Old 01-29-2004, 02:45 PM   #4
I was planning on using the A4 console but I was lucky and aquired an M6 one. Just traded my A4 top half for a guy that had an M6 top half. IMO, I think the M6 one looks a lot more cleaner. But it looks like you did a good job on yours.
Old 01-29-2004, 02:55 PM   #5
LS1Tech Co-Founder
M6 ones are hard to come by cheap so we just tried this to see how it looks.
Old 01-30-2004, 01:42 AM   #6
Well we finished up tonight. Took some more cutting and welding. BIG thanks to 4mulaJoe and Brains for all their help!
Here are a couple more pics I took with the camera phone. I believe Joe has more he will post up.
Pro Ratchet Install with M6 console-shifter.jpg   Pro Ratchet Install with M6 console-shifter2.jpg   Pro Ratchet Install with M6 console-shifterplate.jpg
Old 02-02-2004, 06:00 AM   #7
sleepersilverado's Avatar
PSJ does your shifter have a shorter riser or what ever you want to call the thing the shifter **** screws on to? my friends looks longer?
sleepersilverado is offline   Reply With Quote
Old 02-02-2004, 10:05 PM   #8
Damn going from the M6 definitely looks much easier. I took alot of pics today of the plate that I fabbed up and installed. When I get my shifter done I will post a link to all of the pics.
Chad00ws6 is offline   Reply With Quote
Old 02-03-2004, 02:06 AM   #9
Moderator
BizZzatch350's Avatar
That looks great guys, I have seen Joes and it looks real awesome.
BizZzatch350 is offline   Reply With Quote
Old 06-27-2004, 06:53 PM   #10
WhatCam?'s Avatar
I am considering getting a pro ratchet shifter or hammer shifter for a full manual reverse valve bodied th400. How well does a ratchet shifter work on the street. If you want to downshift to pass somebody, can you just bump it back forward? Both shifters look good, any advantages on mounting them over the two?
WhatCam? is offline   Reply With Quote
Old 06-27-2004, 07:21 PM   #11
Formerly 4mulaJoe
LS1x2's Avatar
Quote:
Yup. Just slap the shifter up once to downshift with a reverse manual. A reverse manual is also quicker for 3 point turns and such as opposed to a forward manual, but still it is no big deal.
Old 11-13-2004, 09:08 AM   #12
SOM WS9's Avatar
What did you do with the reverse lockout?
SOM WS9 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Ratchet shifter in a4 console 993.8camaro Drag Racing Tech 21 01-08-2017 05:19 PM
Custom shifter plate: B&M Pro Ratchet in factory console.. JustAFooL Parts Classifieds 59 11-18-2016 07:06 AM
Hurst Pro-Matic 2 Ratchet Shifter Bigschwerm Parts Classifieds 5 04-02-2011 12:14 PM
B&M Pro Stick install - pics S_J_H Automatic Transmission 3 03-07-2005 10:38 AM
Tags
2000, 4mulajoe, bm, camaro, console, custom, ls1, ls1tech, m6, pro, ratchet, shifter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
