stall question
with the car warmed up to its' normal operating temperature,gear selector in N and engine at idle,drop gear selector into D,the amount of the car wanting to move forward will give an 'indication' of stall. A 'none' or slight wanting to move forward would indicate a aftermarket stall,a strong wanting to move forward would indicate an OEM factory stall.
ALSO a stock OEM converor will 'flash' to about 1800,an aftermarket stall would flash to 2500 or more.
ok i just bought a 2000 camaro. and it tries to jump a little when put into drive. and i can smash it from idle and be all over the road!! that is with tcs off. Would u guys say my car has one??
