Shifting at 6500(limiter) but commanded to shift at 5600...
Old 10-11-2010, 01:20 PM
got-a-ls1's Avatar
Default Shifting at 6500(limiter) but commanded to shift at 5600...
So going to the track recently the trans wont shift at wot until it bounces off the limiter a couple times in 1-2 and 2-3... and i think its killing my mph... i kept lowering the shift points all the way to 5600 but it still wont shift before hitting the limiter. Any ideas? trans is going off to FLT over the winter but i just want to get what i can get out of it now.. lol. Fluid level is normal. I want the damn thing to shift at 6400 when this is all straightened out. If i manually shift from 1-2 it shifts firm but seems to take a few seconds.
I have been keeping the shifter in OD.
tuning or mechanical? thanks
Old 10-11-2010, 01:22 PM
Restricted User
1BAD_LS1's Avatar
Originally Posted by got-a-ls1
So going to the track recently the trans wont shift at wot until it bounces off the limiter a couple times in 1-2 and 2-3... and i think its killing my mph... i kept lowering the shift points all the way to 5600 but it still wont shift before hitting the limiter. Any ideas? trans is going off the FLT over the winter but i just want to get what i can get out of it now.. lol. Fluid level is normal. I want the damn thing to shift at 6400 when this is all straightened out. If i manually shift from 1-2 it shifts firm but seems to take a few seconds.
your shift speed (mph) and shift rpm both need to be met befor it will shift! I bet you need to adjust your shift speed...
Old 10-11-2010, 04:45 PM
got-a-ls1's Avatar
shift speed is definetely met when i look in the logs. its set at 37 which is 5800 rpm 1-2 shift but still hits limiter. Maybe i should try lowering it even more?
Old 10-11-2010, 08:15 PM
Restricted User
1BAD_LS1's Avatar
email me your tune and ill take a look for ya...
Whats your rear gear ratio, stall size/brand????
Blaine
1BADLS1tuningsolutions@gmail.com
Old 10-11-2010, 09:40 PM
got-a-ls1's Avatar
3.23 gears circle d 3600-3800 4c stall. thanks man ill get the email out to ya
Old 10-11-2010, 11:42 PM
Restricted User
1BAD_LS1's Avatar
I adjusted your shift mph and rpm.. see if that works.
If it does then obviously you can adjust from there to where you want it to shift...
on your tune the PART THROTTLE shift tables you have to put the 100% throttle colomns to the same as what you have in your FULL THROTTLE shift tables ..... some pcms are picky with this some are not, i hope that was all your problem was!
Old 10-12-2010, 11:35 PM
got-a-ls1's Avatar
thanks man.. shot you an email back for some reason the file wont open. keeps giving errors. if ya want just post what you changed and i can make the changes and see if it helps. thanks!
Old 10-13-2010, 12:28 AM
Restricted User
1BAD_LS1's Avatar
Put the "normal" "perf" "hot" tables all to the same.....
I think your problem is that your "shift speed vs TPS vs Shift" 100% colomn values were not the same as your "WOT shift speed vs Shift" values... sometimes it causes a pcm confusion, hope this is your problem! If not then its more than likely not the tune and is a mechanical issue (blowing through the trans/stall).
Try these values:
Old 10-13-2010, 12:34 AM
Restricted User
1BAD_LS1's Avatar
ya i forgot im using a new beta version and the current active version of hptuners wont open them...
I had a similar issue as your having when i had my stock 4l60e and vig3600... i was putting 600hp to it and it was just blowing through the clutches and stall. Hope thats not your issue!
Old 10-13-2010, 05:01 PM
got-a-ls1's Avatar
yea im not making 600 horse right now but who knows... Maybe 430 at the most to the wheels N/A. i know the shifts feel firm when they happen so hopefully its just tuning... thanks again for all the help! I didnt know about the part throttle speed and full throttle speed issue so hopefully this fixes it.
Old 03-12-2011, 12:11 AM
98TADRIVER's Avatar
thread revival! lol
How'd you make out?
Old 03-13-2011, 08:52 PM
81LS1Camaro's Avatar
mine used to do the same on th 1-2 shift, then I lost 2nd gear and had to rebuild it. Hope you luck is beter
