Converter lock up question
Old 10-17-2010, 12:28 PM
ls6lou's Avatar
Default Converter lock up question
Hi all,
Long time reader and first time poster. I have a few questions. I just installed a 4L80 with a multi-disc converter into a 2002 Trans Am. While driving around everything seems fine expect the converter doesn't lock up. What do you think? Does it need tuning? if not, what else can it be?
I've tried finding posting on this subject but didn't find a real answer.
Thanks!!!
Old 10-17-2010, 01:19 PM
Circle-D's Avatar
If it is a multi disk it is a lock up. So you need to get a scanner on it and see what is happening. If you have HP tuners you can scan it and manually control it to help solve the problem.
Chris
