M6 console with aftermarket shifter question
Old 10-22-2010, 09:26 PM
sheikss's Avatar
Default M6 console with aftermarket shifter question
Going to switch to an auto. I was wondering if any of you guys have stuck or went to a m6 console. I know I won't have the indicator but want a clean install. I searched for pics of aftermarket shifter installs and only found 1 picture. Alsoi when going from a manual to an auto you have to get the auto harness correct? If you could link me to exactly what I need I would apperciate it. Thanks in advance.
Old 10-23-2010, 03:06 PM
sheikss's Avatar
25 views and no idea's or advice?
Old 10-23-2010, 03:08 PM
ANTICOP RAM AIR's Avatar
probably because few have done what youre going to... most are m6 and love it and others are a4 for consistancy... rarely do they go from m6 to a4... but i can give you a list of what i know you will need... if you want...
Old 10-23-2010, 03:18 PM
sheikss's Avatar
Thank you Sir, I got one 6 speed car already. Want to turn the ss into a track car. If you got part numbers that will be even better.
Old 10-23-2010, 03:27 PM
part numbers???? couldnt tell you that... but i cant tell you that if you find someone on here that will trade you, AND do the work.. i am positive someone will do it.. i would... if i didnt live in DFW.. thats why i got an auto this time... seriously. post up a trade.. your tranny alone is worth 1200 not to mention all wiring electronics and assemblies with clutch basket and shifter.. thats an easy 2k conversion... offer up a trade.. i promise you will find someone who will go for it...
Old 10-23-2010, 03:58 PM
00silver6's Avatar
https://ls1tech.com/forums/automatic...installed.html
i kept my m6 console and it looks good the only thing is i gotta move the console back about a half inch or so cause im hitting by the ash trey , and the stickies at the top of this section will have a write up of what you need and what will work hope this helps
Old 10-23-2010, 05:06 PM
Default console or tranny switch
ok, so i thought you were wanting to go from an T56 tranny to a 4l60 and wanted info on the swap... are you just wanting to put a ratchet shifter on your existing 4l60?
Old 10-23-2010, 08:42 PM
sheikss's Avatar
You are correct, I am currently a m6 car. When I do go to an auto I want to install a racket shifter with reverse lockout. A guy here has done a b&m hammer shifter with the manual console and it looks factory, minus the gear indicator of course. It's what I was looking for, thanks for the help, I apperciate it.
Old 10-24-2010, 08:40 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I've got a B&M Pro Ratchet in my car with the M6 console, pics are in the thread that 00silver6 linked
Old 10-25-2010, 08:58 AM
Photochop's Avatar
I've got a B&M Stealth Pro Ratchet under my stock M6 console, shifting a 4L80.
Old 10-25-2010, 09:43 AM
you can use an auto console with indicator and make it look factory, you may have to make your own indicator label but it can be done... its on here somewhere...
Quick Reply: M6 console with aftermarket shifter question
