rossler customers, come inside
Old 10-30-2010, 01:04 PM
Bobsmyuncle's Avatar
Default rossler customers, come inside
With multiple 4l60e cassulties, time to go th400. So, i was wondering, if anyone has a trans from Rossler, post up what model, how much, how long it has lasted, and how much power u make THRU it. They are local to me and I'm thinking about pullin the trigger on a nice unit
thanks
Old 10-30-2010, 01:10 PM
trans2000am's Avatar
rossler builds a hell of a trans his th400 are top of the line
Old 10-30-2010, 02:26 PM
he has like 6 different ones tho, none have hp ratings
Old 10-31-2010, 11:49 AM
anyone????
Old 11-01-2010, 02:55 AM
nobody
Old 11-01-2010, 06:01 AM
JBM
JBM's Avatar
Best in the business. What you have him build is all relative to your budget and application. A heads up type build will run close to 6K. A street/strip build that will be bullet proof will be around $1500.
Old 11-01-2010, 06:06 AM
lordrazo's Avatar
he is the best!! the t2 is most peoples best pick the t3 is only difference is the billet input and drum but his drums are machined in house and are light weight and strong other than him i would see fti converters in florida
Old 11-02-2010, 02:37 PM
02WSSICK's Avatar
get a terminator 2 with the aluminum drum, awesome trans
Old 11-02-2010, 06:00 PM
Gingervitis Addict
slow67's Avatar
There is probably half a dozen or more th400 builders in the US that are every bit as good as Rossler.
Old 11-03-2010, 09:59 AM
LS1Tech Sponsor
FTICONVERTERS's Avatar
give us a call as we are price competitive.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 11-03-2010, 11:08 AM
1lejohn's Avatar
Rosssler 4l60E. We have put close to 700hp through one numerous times. If you are going to go with a 400 why not just do a glide.
Old 11-03-2010, 12:42 PM
TPIIROC's Avatar
Honestly I just order a trans brake from Carl. Talk about customer service. Will go out of his way to answer any questions and explains everything. I would recommend stopping by and talk to him about your car and what you want.
Old 11-03-2010, 01:52 PM
69TA's Avatar
I have a new ATI turbo 400 for sale
rmvb, transbrake, deep aluminum pan,
quick disconnect, ect.
Old 11-03-2010, 03:38 PM
like i said, they are local to me, and i believe they are THE best, and THE cheapest. they got the faastest automatic in the world.
Old 11-03-2010, 03:40 PM
sry, i will never buy another 4l60e again, theyre garbage. as for a glide, its a street car, and a glide would be a PITA. i drive it nearly everyday
Old 11-03-2010, 03:42 PM
ive heard nothing but good things from that place. customer service is always described as 100% perfect. mostly the reason i am choosing them, plus they build badass trannys and are the cheapest around.
Old 11-04-2010, 03:08 PM
1lejohn's Avatar
Do a 4l80E then if its a street car.
Old 11-06-2010, 08:24 AM
forcd ind's Avatar
def if its a newer street car that had OD, i would go with a 4L80E, keep the OD
Old 11-11-2010, 10:49 PM
who else has theyre th400??? im not buyin a 4500$ 4l80e.
Old 11-12-2010, 09:38 AM
Gingervitis Addict
slow67's Avatar
Other builders have better priced 4L80Es.
Quick Reply: rossler customers, come inside
