lt1 4l60e 0n 99 ls1
I personally would not recommend doing this however it can be done with time and money. I would look for a 96 and later unit so you have a compatible valve body, pump, spacer plate, and internal electronics. You will need a custom converter or crank spacer so the pilot on the converter is supported by the crank shaft. IMO just get the right 98^ unit and be done with it. Vince
